What is the trick to using the mechanical key to open the driver's side door?
The manual says at p. 3-11 to "remove the cover" but conveniently fails to mention how. It looks like you push the little tab in with the key and then swivel the cover up and off, exposing a key hole. But no luck so far, and I don't want to break anything by forcing it.
The key works just fine on the trunk.
