Parking sensor type issue
shauntm
Recently my 2012 R-Spec is blinking green in the center bumper even when the parkng assist is off. It usually happens when i am braking down to an idle even when there is nothing in front of me. This has become a constant thing. Like I said it flashes green instead of the red and makes a alarm noise different than the parking alarm.
Attached is a photo
It's probably faulty. Take it to the dealer and have them fix it (warranty).
If it's intermittent, then take a video of it on your phone first, then show the video to the service writer if they can't reproduce it while you're there.
Video documentation was acceptable to my service rep today. Being replaced but requires removal of front bumper.
Mine did the same thing.
http://www.genesisowners.com/hyundai-genesis-forum/showpost.php?p=116338&postcount=1
Problem with the center fail, is that there are two sensors that can be bad. Figuring out which one is the problem. If the failure is active upon start up, it's best to drive it to the dealer before shutting it down so they can pull the code. That system does not store any faults, so once the car is off, the codes go away until the car does a self-check upon engine start the next time.
My issue was intermittent, so it wouldn't come up every time I started the car. Ended up being the right-front sensor.
Right front for me also. No codes but they claim they detected faulty wiring.
