MOHpro
- Jun 2, 2018
I have a 2012 3.8 sedan. The passenger power folding mirror was not working. When i pressed the button to fold the mirror, I could hear the motor engaging, with a clicking noise. I figured a broken gear was the cause. I ordered a new gear (metal instead of plastic like the OEM one). I took the mirror off the door, disassembled it, and replaced the broken gear in the motor. I reassembled the mirror and put it back on the door. I then tested the power folding function and it worked. Replacing the broken gear fixed it. After doing this repair, when putting it in reverse, the mirror does move down automatically like ot should, but when I take it out of reverse and put it back in park or drive, it does not automatically return to its original position like it should. Also, if I use the mirror asjustment switch and move the mirror in any direction, the mirror moves left and right and up and down like it should. However, if I adjust the mirror position and press the 1 memory button, it will not return to the position I have stored in memory. Instead it does something weird. If I press the 1 button on the memory switch, the mirror will move up just a bit, then to the right just a bit, then up just a bit more, then to the right a bit more. The driver's side mirror is functioning as it should in every way.
Am I suppose to do some kind of reset procedure, since I disconnected the mirror from the car to do the repair? I do have an AllDataDIY subscription. It mentions the IMS module is located under the driver's seat and there are 4 electrical connectors connected to it. Is this true, and do I have to disconnect the four electrical connectors to do a reset on thr memory system.so that the passenger mirror works as it should again?
