Phone sounds and Bluetooth
phar44
I guess I'm having bad Bluetooth karma:
Today I noticed that when iPhone 5 is connected to Bluetooth, my alerts/sounds are silenced (text message, new VM, email, wake-up, etc.). When I realized I was missing alerts, I turned off Bluetooth and, Voila, sounds are there again. Anyone else? Thanks...this is a great community.
Its probably playing through Bluetooth audio
Depending on the Bluetooth data type sent by your phone for voicemail alerts and what-not, the car may not recognize those sounds as similar to phone rings that should interrupt whatever other audio is playing. Plus, the Bluetooth ring volume is separate from the other volume on the Genesis system; at least on the Tech packages. It's possible the Bluetooth ring event volume is zero even if volume for all other audio is turned up. While the phone is actually ringing, check/change the volume to adjust it. Then answer the phone.
mike c.
