Midnightsun
If you figure this out and everything else works as it should when activated, I will send you $50, seriously. However it must be as simple as a few wires to add or solder which I am quite handy at.
Maybe you can help with this. I hate the fact you have to push the DIS knob to get erase the warning screen every time you fire up the engine. A simple logic control with a time delay of maybe 5 seconds when you fire up the engine which then simply sends a momentary ground signal which would mimic the manual push. Once located, then we need to find where to solder the ground wire.
