please help electrical issue
g1money
The ESC light, ABS light all come on, then I start to lose acceleration, then my radio dies then air conditioner then all acceleration and then dies. When I try to restart, get the clicking/dead battery sound. This has come out of the blue...do you have any idea?
Sounds like a bad alternator and has resulted in your battery getting drained to the point where it didn't have the power to run the car and now start it too. If you do charge the battery and get it running again, check the voltage output of the alternator
*IF* the battery and all engine compartment fuses are all OK, then check the fuse block on the top of the battery. The fuses there can fail, and the bus bar can get hairline cracks and fail intermittently, showing some of the behavior you mention.
update: the connection to alternator was corroded previous owner never replace the splash guard so years of no guard with water getting in it messed it up. thank you for your help
