Power steering issues
Dailyj127
Anyone else have trouble with their power steering going in and out. I’ve had this issue for about 4-5 months and it’s progressively gotten worse. I’m looking for a new pump but don’t want to spend $500 if anyone else has had the same issue and there’s a different fix
You'd probably be best off asking this in the 1st gen forum one more down. This is the 2nd gen side and we all have electric power steering ;)
Wrong forum, but the solution is the same for most cars with bad power steering pumps. Just buy a replacement power-steering pump.
I would try an aftermarket brand(if available) if the new OEM pump is too expensive. I would not go with a used power-steering pump unless you are selling the car soon. However, if you have the electric power steering pump then you have to be prepared to spend a few hundred dollars even for a used one.
