John Lipari
The old badge is not glued on,no amount of heat will help get it off. It is stamped in and the metal goes down deep into plastic. You can pry it out with a knife but yiou may damage plastic around badge. I did minor damage. after you pick the metal out bit by bit also using long nosr pliers,you have a raised "H",embosed under the removed badge.The new badge will not stick to it at all. Adhesive must be used. Good luck.
