gameday22
Hi all,
I recently started having a problem which is causing the black plastic around the inner lip of the bumper in the wheel well to keep popping out.
The plastic part of the bumper that holds it in place is roughly 1/4" in width at best and it appears that it keeps flexing enough to allow the black insert enough room to slide out from behind it. It happens when I get the car washed and also when I get up to speeds of 50+ mph, or go over speed bumps.
I talked to my service department manager today and he looked up TSB's to see if anything had been noted about this issue, nothing was listed. We went onto the showroom floor and looked at a 2012 and noticed that the material used inside the well has been changed and they also put some sort of cross brace behind it to prevent it from being able to flex.
Has anyone else experienced this problem with their 09-11 Genny?.....Thanks
