Questions about rubber gasket around rear brake light
It should be covered by warranty 100%. The part is around $200 and there are a few slightly different part numbers. I'm trying to find a DIY instruction to replace it. Looks like the rear of the headliner must be removed. trying to mickey mouse it with black tape is just wrong.
Black tape on such a nice car is so wrong!+
i have the similar problem . do you know what is it called?
My rear brake light gasket/seal just decided to fall out last week - I have an extended warranty, but from what i have read, they will not cover it. Is this terribly expensive at the dealership or is it something I might be able to do myself? I also need a driver side rubber window/door seal, any thoughts on replacing that?
Just went over 86K miles on my 2015 and still loving driving it every day
You just need to get a new 3rd light assembly and install it. They're $120. Don't go to Ebay as they're all already messed up, go here instead.
Go here for install directions. Reply #16.
It's easy to install yourself. I don't know about the door seal, however
Hello. Check out this gentlemen's video on youtube for repair procedure.
