Radar Detector hard wiring to the fuse block Info
dequardo50
Have read a lot of the other posts. Most relate to tapping into the mirror wiring with a Blendmount. I prefer to hardwire my Uniden R3 to the fuse block.
I used the 10A fuse for the wireless charger with a fuse tap. Second row to the right of the main Fuse On/Off switch (which I've never seen before BTW). Finding a ground was the toughest part. Hope this helps others.
I am struggling with the ground as well. Where did you end up finding one?
I wired mine to the OBD, it has fused ignition and ground there.
I used a knock off blend mirror tap for the radar detector but a fuse tap for the dash cam. Thier mount is unfortunately worth the money though. 😔
With the side panel off there is a bolt that connects to a metal bracket that looked attached to frame further in. I used that and no issues so far.
