Radio swapped-now dual lines on camera and no top view
Riiiiise!
Thanks everyone, my dealer didn't know what to do and the Canadian TSB solved the problem
Hyundai should be adding this programming step to the head replacement procedure. It's silly that this happens whenever a head unit is swapped, and the dealers don't know how to fix it. A TSB and/or adding the camera programming step to the swap procedure would solve that.
Yes, that would make sense. Instead, they spend an hour or 2 answering the same question over and over again. My head unit was replaced 1.5 years ago and Hyundai still has not documented this procedure for dealers. Sad.
I too am encountering this issue after just having my radio replaced. I started a second thread about the issue (I am having a lagged boot time as well on the new radio), and will update both threads as I have them. Currently awaiting a response from the dealers technician as to a solution.
Darn. A set-up issue is probably why my radio do not change to a top down view correctly. I need to find how to enter the advance menu to try to set mine up correctly.
