Re: Turning ESC off
the M5 beast
Marion, Iowa
Re: Turning ESC off
I have a 2011 4.6 sedan. I tried the fuse pull replace, but I had 3 lights after I put the fuse back in. One was auto hold. next was esc. and the last was epb. Can anyone give me an insight as to why the auto hold and EPB are still on. The car will go forward and reverse and it don't feel like the brakes are on. Can any one else give me any ideas. I think one other member had the same problem but no one replied to his post. Thanks in advance for any help or advice.
Re: Turning ESC off
I'm not sure which fuse you removed, but ESC module communicates with EPB & AVH (according to hmaservice.com). And since ESC system is a safety system, it is probably notifying you that there was some fault detected (you removing the fuse). You probably need to go to the dealership to get the code cleared.
Re: Turning ESC off
This is a question from another thread that showed how to completly disable the esc by removing the fuse. It worked for other people except me and one other fellow who got the same warning's as me. replacing the fuse and starting it back up got rid of all of the warnings. Would like to be able to disable the esc if someone can tell me why it doesn't work on my car.
Re: Turning ESC off
This is the post I'm reffering to. Any help
WOW,
I'm surprised at how little attention this is getting compared to the original thread about removing the ESC fuse to let her rip.
I thought everyone would want to try this...well, anyways here goes...
Disclaimer, * WARNING * this procedure is not recommended or endorse by either Hyundai or the owners of this site, I have no responsibility whatsoever on the outcome of these tests, please DO NOT TOUCH your vehicle as doing so may cause any number malfunctions and you alone will hold full responsibility of your actions.
I am not associated with Hyundai in any way and have no prior knowledge of inter working of any specific part of the Genesis electronics. Personally, I am purely looking into the problem as engineering enthusiast who wishes to understand how things work.
Very easy.
1. Start the car
2. Pull the 10a ESC fuse
3. Press the ESC button inside the car
4. Put the fuse back in
5. DONE...Please be careful...your monster is unleashed
As I said...The cruise control does not work anymore
You CANNOT engage ESC till you restart the car.
I apologize for those who PM'd me for not getting back. I wrote this because no came back to me and I copied what PINGGOLF put in his thread about pulling the fuse.
Good luck and let me know if this works for you.
Re: Turning ESC off
Very easy.
1. Start the car
2. Pull the 10a ESC fuse wait 10 seconds
3. Press the ESC button inside the car wait 10 seconds
Make sure you do the bolded part...hope this helps.
Re: Turning ESC off
Thanks, but I did that to no avail. Anybody else have an idea.
Re: Turning ESC off
Can somebody explain, please, what is the advantage of turning ESC off?
Thnx.
Re: Turning ESC off
M5 beast,
sorry it's not working for you...maybe Hyundai discovered this and modified something on the newer cars so it can not be deactivated. I just don't know
I can assure you that on my 2009 model, I can completely disable it.
hope you find a way.
Re: Turning ESC off
Thnx.
When disabled using the above method you lose all traction control, you can drift. You can get a better launch. If you just push the ESC button on the dash to turn it off all it does is raise the threshold as to when the ESC kicks in and limits power to the rear wheels.
Re: Turning ESC off
M5 beast,
They must have as the other person showing the same symbols on the dash was also a 2011. Thanks.
Re: Turning ESC off
Check under the hood for fuse , not inside by the door
Ppp
Re: Turning ESC off
Ppp[/QUOTE
The one under the hood is the one I pulled. Thanks for the suggestion tho.
