Rear Seat Problem
CoachDStew
Eastvale, CA
:mad:
My first post. I'm really digging my new 3.8. However, I've had an ongoing issue with the rear seat popping up on the left side. Has anyone had this issue? The dealer has replaced the connector, but the problem persists. Any input or advice would be appreciated.
First of all, welcome to the form and the Genesis club.
I own a 2011 3.8 and do not have any problems with the seats.
Would be interested in the finial conclusion though.
The dealer located the problem. There was a "module" under the seat that was not aligned correctly, causing the seat to pop up. Alignment corrected. Seat fixed. All is well with the world now. ;)
Thanks for the feedback on the solution to the problem.
Always interested in the solution to weird problems. You indicated that the dealer found a “module” not aligned property. I assume that the “module” was some kind of locking device that holds the seat in place. :confused:
the "module" hes referring to is the metal tab/railing that pops into the "connector". its pretty much the only thing that can be misaligned in a seat.
