Recent ECM Recall
Rey
Salem, OR
Was in dealership to replace a worn drivers-side body weatherstrip under warranty; and the dealer said my ECM would be reflashed under a recall to update a condition that manifests itself as a false reading of lean burn condition. I have not had a problem with this. It usually is indicated by a check engine light.
Whatever, you may wish to act on this recall. The reference on my invoice reads: "RECALL #TB9 BH ECM UPDATE-DTC PO456"
"CAUSE: 00C040R0 RECALL"
What's the build date of your car?
Also, how did the bad weatherstripping manifest itself? Did the car leak?
My build date was May 28, 2009.
The weatherstripping was worn at the point where my shoulder would roll against the door frame when exiting. I don't see the wear as a product defect. Rather, I need to lose some weight, and to make a more conventional exit.
My build date was 5/20/2009, so I guess mine falls under the affected VIN range?
I'll have to check with the dealer.
Thanks for the heads up.
Dan
