Greetings,
I drive a 2014 5.0 R-Spec. I did a little test to see if using regular would adversly affect MPG. I live in the Colorado Springs area so my driving has been in higher elevations (between 6000 and 7000 feet). I don't know if that makes a difference or not, I thought I should mention it though. And, due to the altitude, the octane ratings are lower here than they are at sea level. I checked the milage with each fill up the old fasioned way and didn't use the car's MPG readout. I ignored the first tank full when computing MPG after changing to allow the OBDII to adjust. I drove 1,117 on premium and averaged 21.55 MPG. Then I changed over to regular and drove 893 miles and averaged 21.80 MPG. The slight difference might have been due to variations in traffic conditions. But, as you can see, regular seems to yield about the same as premium.
