Does anyone know the process or have a video/write up on removing the intake manifold on the 5.0 V8. I have a little over 30k miles and wanted to check for carbon buildup on the intake valves and then clean with a bore brush if needed.
I might even invest in an adaptor to walnut blast the valves since I already have a small sandblaster. Just wondering if anyone has done the job themselves. Can't find anything on youtube or this site related to pulling the manifold for the 5.0
Thanks for any input. I'll document the process if I decide to go ahead with it.
Here is the information I obtained from the Hyundai service manual. Sorry, the pics did not copy over and the links are closed.
GENESIS(DH) > 2015 > G 5.0 GDI > Engine Mechanical System
Removal and Installation
1. Disconnect the battery negative terminal from the battery.
2. Remove the air cleaner assembly.
(Refer to Intake And Exhaust System - "Air Cleaner")
3. Remove the fuel hose (A), the purge control solenoid valve (PCSV) hose (B) and the brake booster vacuum hose (C).
4. Disconnect the ETC module connector (A), PCSV connector (B), the PCV hose (C) and ETC water hose (D).
5. Disconnect the MAP sensor connect (A) located at the rear side of intake module and remove the wiring harness protector bolts (B).
6. Remove the high pressure fuel pipe and tube bracket bolts (A).
Tightening torque :
9.8 ~ 11.8 N.m (1.0 ~ 1.2 kgf.m, 7.2 ~ 8.7 lb-ft)
https://www.hyundaitechinfo.com/viewer/print_pop.aspx?pos=2$9_8_2...
7. Remove the LH/RH bank foams (A).
[LH]
[RH]
8. Remove the intake manifold module (A).
Tightening torque
1st step :
4.9 ~ 7.8N.m (0.5 ~ 0.8kgf.m, 3.6 ~ 5.8lb-ft)
2nd step :
19.6 ~ 26.5N.m (2.0 ~ 2.7kgf.m, 14.5 ~ 19.5lb-ft)
9. Installation is reverse order of removal and tighten the manifold nuts with specified torque in the sequence shown.
