Trojanlawyer
- Jun 7, 2020
- Genesis G70
Based on the Mono-Tube system with ride height and damping adjustments, Riaction sport coilovers can be customized to match your driving style. Riaction uses quality materials merged with precision design to deliver a unique, and fully rebuildable coilover.
Riaction sports coilover kits are designed for street cars which are looking for lower ride height, better handling, and greater comfort. Each set of Riaction USA coilovers are made from high quality materials with precision design, to ensure a reliable and durable product.
Coilover Kit Features
Camber adjustment
Full Length Ride Height Adjustment
32 Damping Adjustment Levels
Mono-Tube Damper Design
Seamless 52mm Electroplated Carbon Steel Shock Body
O.D. 20mm Piston Rod For MacPherson Suspension
O.D. 14mm Piston Rod For Non-MacPherson Suspension
Unique 44mm High-Flow CNC 6061 Aluminum Piston
Unique Thinned CNC 6061 Aluminum Floating Piston
Polyurethane Oil Seal
SAE9254 Cold-Wound Spring
Multi-Thickness Valving Shims
Unique Low-Gas Pressure Design
7.5w Compounded Suspension Fluid
Fully Rebuildable
These were professionally installed by Riaction in El Monte. I drove on them for less than 3k in my G70 and are awesome. Giving my car to my parents so uninstalled them (also by Riaction).
Mike
Camber adjustment
Fully Rebuildable
Mike
