Scc sensors
Chipstott
I recently purchased a 2011 4.6 Genesis sedan and after a couple weeks of having a car and getting what I think they call is an SCC sensor indication on the dash. The symbol is a little car with a P in it and then for my instants it has a little flash symbol of the left front corner. I was hoping to learn what this means and if it’s a malfunction of some sensors
Sounds like the same mine is doing, cruise module issue.
Smart Cruise Control Module malfunction symbol. It's stated in the owner's manual. It's a Module with a motherboard in it. Problems can range from a simple one problem like:
1) Electrical Connector just being disconnected from unit
2) Water or Debri Damage
3) Front end Collision Damage
4) Wiring Harness Damaged
5) Wrong Part Number Installed
Etc
If it is a symbol with a (P) then it's the electric parking brake.
If this light is on, it's the SCC system.
If BOTH are on, then you have a brake system failure.
Mine is that wonderful bugger.
Well that's a bummer.
There's a host of stuff connected to the SCC system, so it can be anything from a single wheel speed sensor to the HECU to the radar module itself. These faults normally won't throw a CEL through the ECU so cannot be scanned via OBD2. But someone with a Hyundai diagnosis scanner can pull the correct fault code. Otherwise they'll just be firing the parts cannon at it, using your wallet as ammunition.
That is the best line ever!
