Slight Pulling to the left/right
I just put on new Falken 722's 275/40/19 on back and 245/45/19 staggered setup on front.. Rides better than the 50 profile pirrellis i had on previously...
Any time you put on brand new tires, steering will be somewhat straighter simply becasue the tires are flat on the tread. As the tire wears, any slight imperfections in the steering will cause uneven tire wear, and then the steering problem gets worse. Assuming that the wheels are properly aligned, then making sure you rotate the tires on a regular basis will help (and check tire inflation regularly). Otherwise you may be buying new tires just to fix the steering, even when they have plenty of tread left.
