Some differences with the 2014 Signature
I believe DRL (which I assume are Daytime Running lights) are a federal law so there must be some way to turn them on.
What country are you talking about? They are not required in the US.
Exactly. Well next year they are switching to Android so hopefully, Google maps will work. <G> I believe DRL (which I assume are Daytime Running lights) are a federal law so there must be some way to turn them on. Maybe they just need to move the connecter pins around like they had to do before.
What does Google maps have to do with NAV?
As for the DRLs, yes it could be that simple if Hyundai authorized the fix. So far, Legal hasn't approved that fix. The poster that had it applied is lucky.
Regarding the DRLs, has anyone installed a switch enable one to turn on/shut off as desired?
I forgot, the 2014 cruise does not let you change distance for auto slow. It set. 20412 it can be changed. If there is a lumbar support I could not find it on seat. The clock has an analog dial, it works off gps signal and can not be manually set.
the lumbar is not on the door, it's on the side of the chair... it's on the left side of the chair if you are in the drivers seat...
I wish I had a digital clock somewhere in the car.
and the autocruise distance is on the wheel, it's the lower switch, the one above it is cancel cruise...
