steering error... help
Smitty15Gen
S.W. Florida
New to me 15 Gen, Had It a week. The headlights seemed pretty low. So I searched the site, found out others where having/had similar issues. I also found how to adjust the headlights. So I did that tonight, way better.
I get a couple blocks away from home (test drive) and I get a check hepitac (probably spelled it wrong) error. So I hook up my cheap code reader, tells me no codes.
So how do I reset this?? Can I use the scan tool at work? Or will I need to take to the dealer???
Fyi, car steers fine, lane assist does not work.
Thank you.
Thank you.
Takes a dealer-level scan tool to read the code. Haptic is just the vibration motor mounted to the steering column. It may be failed or stuck.
Great!!!!... ok. Thanks.
Alright, So I tried the Scan pro at work. I was able to clear the code. Eveything is working ok.
