Stock size
MeyerKy32
Shakopee, Minnesota
What is the stock size for the 2010 Genesis Sedan wheels and tires..?
is it 225/50r18 ?
would a 235/45r18 fit?
is it 225/50r18 ?
If you don't have an owners manual, you can log on to www.myhyundai.com (free registration) and download the owners manual with all the tire and wheel specs.
Once you get the right wheel and tire size, you can go to Discount Tire website and see what alternate sizes will fit your wheels.
I was just wondering because I just ordered some Nokian WR G3's size 225/50R18. thats the size on my car currently. I did find itonline it was 225/55R17 is the stock size.
The Base trim model used 17 inch rims, and the Premium and Tech Package (and V8) had 18" rims. Check the Owners Manual for the exact OEM sizes. The Owners Manual is the definitive source. I explained above how to get a PDF version, if you don't already have one.
The 17 inch wheels have 225/55R17 stock and the 18 inch size is 235/50R18. The 225s you ordered should be fine as the size difference is very minor and they'll be all the same size.
225/50R18 is 1.5% smaller diameter than the stock 235/50R18. That is probably OK for a winter tire, but I would use the stock size (or equivalent size with same diameter) the rest of the year.
Here is a tire size calculator:
https://tiresize.com/calculator/
