Sunroof tilt track problem and $$$$
CHuntMD
Maryland
2011 4.6 83k miles. Wife's car, don't use the sunroof much due to allergies here in the Wash DC Metro. On the way home yestersday AM from the local Costco I tilted up the sunroof. Pulled in the garage and attempted to close. The motor/gear made all kinds of racket and the rear pass side is a 1/4 higher than the sheetmetal while the rear drivers side is 1/4 lower/ Hear wind noice while going to Pohanka Hyundai right off the DC Beltway.
Found a youtube about sunroof for a coupe but our sedanshave a different configuration. There is a plasting housing that ceeks you from accessing the 3 screws holding in the motor.
Got the call from the SA, $3400+ to fix. Open to suggestions.
CEH in MD
CEH in MD
I'd find a way to close it even it it screws up the linkage. Then, instead of paying $3400 for a repair, I'd use that for down payment on a new one.
I asked about that. No go from them. I did get a PDF version of the service manual from a fellow member so it's going to sit in the garage till the weekend. Might call some shops that specialize in sunroofs.
New car with more safety features is also on the burner.
CEH in MD
I got a quote like that on an older car.
I paid them $200 to close and seal the sunroof.
  • Like
Reactions: COB
Found a place in Glen Burnie MD, will see what they say tomorrow. Plan B will be to just seal it up and disconnect the switch.
please update when you take the next step.
CEH in MD
Had the same problem...never used it, just decided to open it one day, the whole mechanism is made of plastic and it cracked...Hyundai told me $2,500 for a new one....they tried to close it spent an hour and couldn't and my mechanic closed it in 10 min. I've since taken the fuse out so car washers don't touch it. Not worth the money to fix it.
Automotive concepts in Glen Burnie MD has the skill. $800 to fix or only 125 to close up and pull the connector. Got rid of the Genny today due to a combo of other issues. Hopefully will be back in the future with a new Genesis
The track guides are what fail on these.
Too thin of a plastic and not heavy enough grease formulation to bare the load.
Pulling the sunroof fuse is sufficient to disable power.
The manual close option with a flathead screwdriver to hold up the damaged section of guide will get it closed.
Full disassembly required for repair unless you're good with 2 part epoxies.
what type of grease should be used for those of us that have a working sunroof and actually do use it often???
Generally speaking, any heavy duty load bearing grease would be fine.
Lucas green is what I used after I repaired mine.
Hello all, I just bought a 2013 Genesis 5.0. The sunroof works fine on it, but as far as preventative maintenance, where would I put the grease? Just on the track, or can you reach the gears easily?
  • Like
Reactions: COB
There is a dust cover on each side that covers the guide rails, I pulled the covers and put it into the guide channel that the pin rides in.
CEH in MD
You can buy the track online for around $80, make sure you buy the correct side, they are not reversible. Remove three torx head screws, replace the plastic track cover and you are back in business
Hi, can you or anyone else on here give me a place online to look for these? Dealer wanted around $240 per side for the sunroof track assembly. (That May have included cable(s), etc., I don’t know)
