Technical Specs for Wheels and Springs
Nick.Papagiorgio
Genesis GV70
I'm a bit of a nerd, so I like numbers.
I've got the 21" wheels on my 2.5t and would love to swap them out with something lighter. Issue is, I haven't been able to find the weight of a stock 21" rim anywhere.
Similarly, with 2 aftermarket lowering springs available now (Storm and M&S), I'd love to be able to compare spring rates to the stock springs, but I can't find that data anywhere either.
I'm sure I'm not the only one that's been curious about these things, so if anyone can help out it would be awesome.
Sorry I don’t have the weights for the stock 21s but since they’re cast any flow-form (or any of its derivative names) or forged wheel will be much lighter. Although the HRE flow-formed wheels are quite heavy weirdly enough so if you go with any of those, they might be close to the same weight. I think they’re mid to high 30lbs and would assume the stock wheels are close to 40lbs.
I would think they might be heavier based on comparison with my other Genesis rims. I have the 18" wheel set from Genesis that are my winters and those are about 55 lbs average. These being 21" I'd probably think are heavier but I will weigh once I've made this swap again so more to follow.
Are you weighing with the tires mounted? I was referring to just the wheel weight.
