ctrcbob
CTRC, USN Ret.
- Jan 11, 2009
- Genesis G80
I had something else happen to me today, that got corrected when I rebooted the system (re-started the car after letting it sit for a few minutes).
1. Today, I was talking on the phone using the Bluetooth in the car, WHILE I WAS PARKED. Then without thinking, I shut the car off, without shutting off the bluetooth connection. As soon as I did it, I restarted car, but NO Bluetooth connection. The DIS showed the bluetooth setting was correct, but no bluetooth. Then I remembered. "Let the car sit for a few minutes and it will ReBoot on starting car". I let it sit for about three minutes, then restarted car, and I then had the bluetooth connection again.
2. A couple weeks after I first got the car, I started it up, the ESC lamp stayed lighted and car would not get out of Park. (This also happened to another person on this group). Shut car off, and while talking with someone, trying to figure out what was happening, (over three minutes), started car up again (car reboots) and I could shift out of Park.
Never happened again.
3. A few weeks ago, I started car, and AM/FM/XM/CD (radios) did not work. To be more exact, no sound from speakers, as I could see what was playing on the DIS screen. (Again, this also happened to another person on this group). Remembering the reboot, (while I was going for groceries), I was not worried. Went in for groceries (was there for longer than 3 minutes), came out and started car (reboots) and radios (speakers) all worked again.
The only thing that worried me about this was 'what would happen if I got a phone call through the cars bluetooth'? Probably would not be able to hear the person I was talking with. Never happened again.
4. A few months ago, I could not unlock the car. Tried both with the button on the door handle, and also with the unlock button on the key fob. Unlocked the car with the "emergency key". Car did start up in the normal way. When I parked car, I locked it with the button on the door handle. Next time I unlocked door, (car parked for a while) it worked perfectly.
I'm sure there are other things that could (and will) go wrong. When that happens, (and it will), just re-boot (shut car off, let sit for three minutes or so minimum, then restart) and all should be well.
