This car has amber LED as turning signal?
I believe the base model without HID headlights for some reason gets LED turning signals.
Are you sure it's not just how the camera is picking it up? it looks more white than amber to me?
That is the BASE model which is what all the fuss is about on this forum. The base model without HID get the LED front turn signals whereas the upper trims do NOT. Makes no sense whatsoever.
They look GREAT BTW. I noticed this exact same thing live the other day.
so dont you think someone with a background in mechanical wiring can tell us how to fix this at the fuse box? That would be the logical place where all these connections occur. It seems to me that you could unhook a wire from one connection and switch it to another. Sorry Im not the mechanical type.
I would imagine that it is a wiring/connector thing more than a fuse box thing? The controls are the same - it's what the wires are connected to when they terminate that controls which lights come on? But - agreed, someone with the right electrical/wiring skills should be able to figure it out as an aftermarket mod?
I saw one of these the other day which is why I came here to search the threads... so it's only on the base model? That's great... so the cheaper base model Genesis has cooler turn signals and the even cheaper Sonata has cooler DRL's... Thanks Hyundai!
