Today, I picked up my Gen V8/Tech from the dealer after the 1st scheduled service. Upon arriving home I parked the car outside and had a walk around to make sure everything is ok. When I glance down at the tires I noticed something not quite right. On the driver side both Dunlop tires seem to facing the wrong way. Most tires have a “V” shape thread pattern in the middle to channel the water out and away. The pointed end of the “V” is usually pointing forward.
On the Genesis, the “V” is pointing backward on the driver side and pointing forward on the passenger side! In other words, water under the tires on the driver side is push toward the center of the tire with no place to go – A great recipe for hydroplaning!
So I thought the dealer may have goofed when they rotate my tires. After thinkink this over I come to the conclusion that no matter how they rotate the tires two of the tires will always facing the wrong way.
I drove back to the dealership and look at the unsold Genesis on the lot. They are all the same. The “V” on the driver side is pointing backward and on the passenger side the “V” is pointing forward.
Can someone tell me are the Dunlop 5000 tires suppose to be mounted that way
I can’t imaging Hyundai is mounting the tires the wrong way.
