Tires
Avtoshka80
Genesis G90
Second blowout in 3 weeks. Front tire ran over piece of metal. Second pothole rear tire
If you live in an area with a lot of potholes, you may want to go to a higher sidewall tire, and/or buy after market 18 inch wheels, which will give you more flexibility when choosing tire sizes and amount of sidewall you want.
This is good to know. I had a 2015 Genesis that I loved, but the roads in West Texas are horrible and there is oil field debris all over. So I kept blowing out tires. Eventually I went to a different vehicle because of that.
I still love the Genesis and am looking at a 2021 G90 5.0. But for sure I'll need a tire with a bigger sidewall.
What's the rationale behind after market 18 inch wheels? Are the stock rims bigger or do they limit how much sidewall you can have? (Please forgive the questions, I know jack about rims and tire sizes etc lol)
Thanks!
Thanks!
If you keep the outside diameter of the tire the same as your 19" wheel/tire set and run on wheels that are an inch shorter (18") you have an additional 1/2" of sidewall tire height (1/2" on bottom, 1/2" on top to visualize). If you go to a wheel that's an inch taller (20") you'll have a 1/2" shorter sidewall than your 19" wheel/tire setup. That's why 20" tire setups ride so rough, there's not much tire to absorb any impacts.
