Tires
rgarret2
Thinking that the OEM rear tires would last 20k+ miles, instead they lasted less than tires of higher performance cars...a whopping 10,500 miles. I drive the car less aggressively than I have others and do not enjoy putting down 30+ foot burnout strips on the street or strip. For being LRR tires, they're noisier than the ones I replaced them with...Potenza S04 Pole Position at all four corners. Another issue with the Conti's was hydroplaning...not an issue with the Potenzas, under reasonable speeds
The reviews on Tire Rack were accurate for the most part and not only are these quieter, but transform the handling to respectable levels. The squealing is gone and makes the Equus very enjoyable to drive and behold...allows for tossing around a bit. You won't end up with BMW or AMG handling, but at least you'll have more fun driving the big horse around.
I bought the tires from my local tire dealer for the same price as TR after tax+install. For owners in northern climates, get the RE970AS Pole Position-4 season, if you don't get dedicated snow tires.
I agree the Continentals are awful. I just replace two at 15,000 miles.
RE970AS are decent, however they are 3-season tires, not 4. They shouldn't be used in the snow, and if you're gonna run dedicated winter tires then you might as well consider summer tires instead of UHP all-seasons.
+1
The OEM Continentals stink. I have 13,000 miles on them and they are slightly "thumpy". Just had second road-force balance on them in 6000 miles. Dealer almost replaced them under warranty due problems with balancing them, but dismounted and remounted a the fronts and said "fixed". Will buy another brand when replacement needed.
RE970 as are better than average. They shouldn't be utilized as a part of the snow, and provided that you're set to run committed winter tires then you should just think about summer tires.
Just to throw more gas on the fire here - my Conti's on the front are showing wear at 17k.
Dealer told me it was due to out of alignment.
When getting it aligned they guy noted the same thing and commented that my wear was one outer edge of tire which is indicative of under-inflation.
I have had normal maintenance at dealer and this was never mentioned. Just frustrated.
Currently putting on Turazana Serenity Plus as replacement on the fronts.
My OEM Continentals lasted 32K. They provided a soft quiet ride, but didn't grip that well in the rain. I was satisfied with their performance.
I replaced them with Michelin Pilot Sport A/S 3+ from Costco. These tires are stiffer (less of a soft ride) and seem to grip exceptionally well. They also work very well in the rain.
Same here. Just had all four replaced at 34k. Michelin Pilot A/S 3+ tires are maybe a little more nosey, but grip better than the Conti's did. Nice to have the car driving nice again.
change rim size to 18x7.5 and tires with 235/50 R18
Square setup?
are you affraid about it?
did you know the sister of equus kia K900 V8 2016 comes with 245/45R19 Front/Rear in some countries.
while in USA comes with 245/45R19 Front, 275/40R19 Rear.
It's somthing back to you and Hyundai made alot of mistake like suggest wrong tyre pressure and tyre size.
for me I will go with rim R18 to provide stronger sidewall and bigger profile
I hear you. I'm not afraid...just curious!
245/50R18 on an 8" wide wheel would work better:
