TPM malfunction
drewaz
Phoenix
I accidentally put too much air in one tire and after bleeding it down to the proper inflation the TPM for that tire reports it's about 4 PSI lower than the others. Checking with a manual gauge confirms the TPM isn't correct.
Anyone know how to reset the TPM?
Thanks
Drive the car for several miles...hopefully it will reset to the correct pressure.
thanks ... have done that with no success. I think I'll bleed a little more air out and try to add some ... see if that works
Before you bleed out more air, use your Gauge to see what the other tires read. If they are all correct, then you have a faulty TPM. If you still have warranty it should be covered. If not the you have to take it to a tire shop to be replaced. New Hyundai OEM TPM's can be bought on eBay for $35-$50 each.
Drewaz
Could you tell us how high was too high. I want to be extra careful not to go too high.
I was chatting away and filled the tire to 40! Blend if down to 34 and after that the TMP was off.
I decided to bleed it down again and filled it up to 34 and after that it's reading is accurate and consistent with the other tires.
