tscherm
- Dec 31, 2022
- Genesis Model Year
- 2012
I've read some posts of other members experiencing the same problem. However, it seems as if the "FIX" is not apparent.
My vehicle will start up and drive normally most days. However, every once in a while my 2012 Hyundai Genesis Sedan has an issue identifying which gear it is in. For example; if you pull the shift knob back to "D" the dash still shows that is in "N".
Once you release the shift knob it kind of "floats" between N and D. It doesn't stay engaged/seated in the "D" position.
I've read that this could be the shift cable assembly, the shift linkage, a possible shift cable assembly that is misaligned, etc.
Has anyone experienced this issue before and actually identified the problem causing it? Or know of anyone that has? The transmission appears to be absolutely fine because once it does identify the proper gear, the car drives perfectly fine with no issues.
Any information would be greatly appreciated.
