Transmission fluid temperature
chrev
Raleigh, NC
Anyone here have an Autel Maxicheck, AL419 or any Autel products? I want to see the transmission fluid temperature and I don't see it in live data anywhere. I know people have scangauge 2 but I don't want to spend another 160 for a redundant tool just to gain 1 feature.
After updating the AL419 I got it to display ATF temperature.
Do you know if the AL419 can read and clear Hyundai airbag codes?
I can look when I get in the car this afternoon. I think it does but I will check.
I have a Bluetooth deal that plugs in to the OBDport and can read this - from what I remember the transmission fluid gets up to just about engine temperature
and that is how it is designed as the fluid flows through the bottom of the engine radiator
I don't think the 419 does ABS but my maxicheck pro from Autel does and it is a two way scanner that can work different modules like the ABS. I did purchase a bluetooth adapter and the torque app to compare it to what I was seeing in my scanner. The thing that confused me is that the transmission and engine coolant temperatures were increasing at the same exact rate with the same exact temperature. The sensor would read over 80C but the pan was no where near it. So I used the infrared thermometer to measure the pan temp. If you want to perform a flush without a lift like I did then the MightyVac fluid extractor is a must have.
I meant airbag not ABS.
