Transmission problems?
CanukV6
Beamsville Ontario
I was on the highway in slower traffic last night, approaching my off-ramp. As I moved onto the ramp, I pressed the throttle far enough to normally trigger a kick-down to a lower gear to accelerate into the uphill ramp. Instead of changing gear the engine revs soared for a few seconds as though in neutral with no load, then there was a loud thump as the transmission banged back into gear. It felt like I had been rear-ended.
Anybody else had this happen in their Gen.2?
I had this same thing occur more than once in my 2012 and that resulted in a replacement transmission. I had hoped they had fixed this problem by now.
you may have sensors problem
go to the dealership and see if there is an error or not let them do Transmission Computer check
Never happened to me in my 2015 or 2016 or many 2015 loaners I've driven - all V6 AWD's.
It sounds like the transmission is slipping. I've had that happen on much older cars (usually a sign that the transmission is starting to fail), but never in the Genesis. I recommend getting your transmission checked out.
And get the typical dealer answer...can't duplicate problem---go away:)
So far it has only happened the once, but I will definitely mention it next time the car is in for service.
I'd swing by to see if your trans threw a code. That can be checked quickly.
I've had this happen to me on my 5.0. I think what you're describing is when you go over a bump or road seam. It looses traction for a second and traction control engages... that's my theory but again I'm pretty sure it has to do with uneven or bumpy surfaces. Hope this helps. Thanks, Paul
No, definitely not a Traction issue. The transmission disengaged completely and then slammed back into gear. This was a smooth highway and off-ramp.
