Hi, I have a 2012 3.8 RWD Sedan Genesis and it's throwing code P0753. It usually does it first thing in the morning and wont shift out of 5th gear. Then after a couple of restarts, it works fine. the code sometimes disappears until the next day as well. This starting happening a couple of days after a transmission fluid drain/refill.
I went to a local transmission place and we found the TSB related to this issue. They are wanting ~$1700 parts/labor to replace the solenoid ($125), ECM ($600), pan/filter($225), and fluid including 6 hours labor. Is this reasonable?
Thanks in advance
Thanks in advance
