Potty_Pants
- Jul 31, 2012
Hi guys,
DI Carbon deposits...
All DI engines are different some worse then others, jury is still out on Hyundai.
I would assume its better to have a lower reving engine generate deposits then a higher reving engine (basically 1500 rpm cruise vs 2800 rpm) ? Note Fuel injection doesnt apply here different animal.
I would assume a larger engine would have more depoisits (on the average)
I would assume a larger engine reving lower would last longer then a higher reving V6 with a smaller intake before walnut blasting was required ?
I would also assume a higher compression and/or turbo would exasorbate the carbon build up.
if you've stayed at a holiday inn express please mention that in your reply.
thanks
ppp
thanks
ppp
