RedBeardCPA
Hi folks,
I'm here to ask for advice dealing with Bank 2 (driverside) misfires which began about two weeks ago, and the car hasn't been driven much since. It idles very badly and I'm afraid to do any damage to the engine. I've instead spent several days reading up on threads here and educating myself using the service manual PDFs. Thanks for making those available, by the way.
I have used an OBDII scanner and software for a short whilte (Car Scanner Pro) but I don't run the engine much, for fear of damage.
Car:
2013 Hyundai Genesis Sedan 5.0 R-Spec 88k miles, last oil change within 5k miles, new H9 battery which appears to be operating normally
Spark plugs haven't yet been replaced but will be inspected shortly
Diagnostic codes:
P0019 -- Camshaft or crankshaft position sensor issues on Bank 2 (driverside)
P0300 -- Multiple cylinder misfires
P0302, P0304, P0306, P0308 -- misfires all throughout Bank 2 (driverside cylinders 2 4 6 8)
Other interesting findings from OBDII scanner:
Fuel trim for Bank 1 oscillates frequently, while Fuel Trim for Bank 2 remains a flat zero
This, to me, seems important! But I imagine this is more the "symptom" than the "cause" -- unless my thinking is backward?
What my research suggests:
1) This could be related to Camshaft Position Sensor or wiring failures?
- Tested wiring harness and got the correct voltages at all 4 CPS connectors
- Have not yet tested the CPS sensors themselves, since I don't have a good Back Probe for my multimeter
- Maybe tonight I'll simply swap the driverside exhaust CPS with the passengerside exhaust CPS, and same with intake CPS sensors, and see if my misfires "move" to the other bank?
2) This could be related to OCV oil control valve?
- There are two of these on each bank, in the front of the heads, and they appear to make adjustments to combustion.
- I removed one last night after GREAT trouble getting it loose from the head. Bolt came out easily enough but the sensor itself took 20 minutes of nonsense and gentle prying and not-so-gentle work with needlenose pliers.
- I am replacing both of these on the driverside because they appear, from my searches, to be a common trouble item.
3) This could be related to Bank 2's O2 sensors or catalytic converter?
- However, I am not getting any trouble codes from O2 sensors.
Asking for help:
If anyone has any guidance, comments, etc -- I'd be real happy to hear about it. I do my best to self-educate, but there's a lot at play here and I'm still fairly new to DIY work on the Genesis. It's certainly not as straightforward as my 95 Impala SS!
Thanks folks.
Car:
Diagnostic codes:
Asking for help:
Thanks folks.
