Trunk opening problem
stuz88
After a minor 5mph rear ender, the bumper on our 2010 was replaced due to a ridge line caused by the reinforcing bar behind it.Previously if the car was locked, the trunk would open if you walked up to it and pressed the release button on the trunk lid if you had the fob in your pocket. Now you have to press the fob unlock button as per manual to get it to open, which is a pain with a load of groceries.
Is there anything that could have been affected when the bumper was replaced or when the car was hit? The damage was very slight
Hidden damage was not repaired. Take it back to the repair shop and tell them to fix it. If you told them you wanted to get out cheap then any additional work is on you.
There are multiple antennas for the car-to-fob communications... including one in the rear bumper. When you push on the exterior trunk switch, the car transmits an identification request command to the fob via the bumper antenna. If it receives the proper code from the fob (via the same antenna) it unlocks the trunk.
It's highly probable that your car's rear bumper antenna is not connected. It might not even be installed if the repair shop didn't move it from the old bumper to the new.
mike c.
