Trunk release button broken, is there a replacement?
Ozrkbnd
I have a 2018 Genesis G80. The button (on the underside of the trunk lid lift area) is cracked/broken. The trunk latch itself works fine, I just want to replace the button. Does anyone know where I might be able to buy one?
81260B?
It is more of a flat button. I'll try to get a good picture of it.
The part number I gave is the one outside the lid to open it. It's also where the rear view camera is. The other buttons back there would be the close button and lock button (one two button assembly). So, exactly what button are you actually talking about?
This is common. the rubber corrodes so the whole assembly should be replaced except for the actual camera. There are diy instructions here in a few posts. That part number is correct.
Do you happen to know the posters or the thread names for the DIY instruction? Havent found them by searching.
Thanks in advance!
