Trunk won't open
Genieowner
My tail lights won't turn off, so I disconnected the battery in the trunk last night.
Now I cannot get into the trunk.
How do I open the trunk of my 2009 Genesis 4.6?
Did you try your metal key to open the trunk?
Welcome. Moved this topic into our first generation Genesis Sedan forum...
Use the manual (metal) key. Remove it from the fob (silver button). There's a key slot above the license plate.
Thank you that worked.
The only way I can open the trunk now is with the metal key. The fuse is fine. Do you know why I can't open it with the key fob? I can't even use the hand opener on the right side above the license plate. 2012 Genesis
Bad (broken) wire, bad solenoid, bad electronic module...
Troubleshooting is required.
