Two Days Away
Cincymark
Cincinnati, OH
Genesis GV60
About to pick up my new 2024 GV60 Advanced. I’m thinking it will take me a few weeks to learn most of the basics. Looking forward to it!
Welcome aboard! And thank you for signing up. I'm glad you found us. Congratulations on your brand new Genesis GV60 Advanced! :) What will the GV60 be replacing for you?
I love my GV60 Performance model and I suspect that you will love your Advanced model as well. Unlike what happens with some other marques, the Advanced has most of the features of the Performance model.
I would recommend you start by familiarizing yourself with the Getting started guide.
On my car, I assume on yours as well, that if you bring up the seat panel on the info display, there is a setting for you to let the car determine your seat setting. I tried it for kicks after setting the car up the way I thought best (seat and steering wheel), it changed everything but I liked it better. So it is a good way to, at least, start off. Either way, use the button on the door to save your settings once you have them.
I would also initially focus on the steering wheel controls. You can control a large part of the car's operation by using the buttons on the steering wheel and they are there and only minimally require you to take your eyes off the road.
Yes...before you ask, you will see that the actual car speed compared to the speedometer is about two miles per hour slower. That is to avoid the car company being sued for causing the driver to get a speeding ticket. And, again before one asks, the odometer is actually correct, just the speedometer is (intentionally) wrong.
Finally, I would suggest adding to your signature your general location. There is a huge difference in how cars operate in Anchorage vs. Phoenix (for an extreme example) and advice you get (and give) will be better if your location matches up with the issue.
Replaced a Volvo XC40 Recharge. Lease wasn’t up until the Fall but the incentives in June for the GV60 were too good to pass up and justified the cost of turning the Volvo in early. So far, (400-ish) miles, I absolutely love the Genesis. The technology and safety features are outstanding and it is SO much more fun to drive than the Volvo. So far, better range too.
Glad to hear it! I'm highly confident the GV60 is going to take good care of you for years to come. :)
One glitch so far. Out of nowhere, I’m getting a “widgets not available in current mode” message when I push the black button on the right side of the steering wheel. Until a few days ago, the various widgets were coming up without a problem. I haven’t yet found an explanation or solution.
If you haven't already, do a quick search to see if others have had this problem - and found a solution. If you don't find anything, start a new topic with a title that draws people in who may be able to help.
