jasonsw
- Jan 12, 2009
Hello all, TPMS (Tire Pressure Monitoring System) went off on Driver side REAR tire for the second time in a month. First time, I put some air in thinking it was a small puncture / leak. Second time around, I took it to the shop. They found no leak, however the inner surface was worn beyond(?) recognition...
Both the rear tires were worn inner surface while driver side was more noticeable.
Tires were rotated about 9,000 miles ago. My car was pulling to the LEFT, so I rotated front wheels (not rear) 2 weeks ago.
Question 1: Could this uneven wear be result of faulty alignment in the front? or faulty alignment in the rear? I noticed that rear tires tend to sit in-ward like this when looked from the back /--\ whereas |--| should be normal for most cars.
Question 2: I think I saw similar alignment in the rear from other luxury cars like that of MBz. Is this done purposely to improve handling or roll-over?
Question 3: Isn't 35PSI the proper pressure for the tires? I noticed it was in 25 PSI or less once returning from the dealer. Could this be done to 'improve' on ride? or overlooked by the dearler?
Thank you in advance.
