Updated my nav system
recruit100
When I updated my nav system, the locks on three doors stopped working, I can hear them click but, they won't open! Does anyone have a fix? Thanks for your help
Charley
Charley
Welcome aboard! And thank you for signing up. I'm moving this topic into our first generation Genesis Sedan section...
Charley
Nav system is wholly unrelated to door locks, if you have an issue it's with the locks or with the security module.
I just can't get the "black" color scheme to activate...
There's a dark mode? Is that in the updated setup area? Also in another thread you mentioned stopping the mirrors from dipping when going to reverse - where is this setting?
For the mirrors, just deselect whatever mirror you have activated. With both mirrors deselected, the mirrors will not go down.
Use the settings with the button on the right side of the steering wheel to find the mirror setting. I forget exactly where, but take a few minutes to go through them all and you may find things you'd like to change.
Black mode is in the nav setting.
Thanks EdP. Was that always there or was that part of the update? I've been through the steering wheel settings a bunch and don't recall seeing that before. I'm going to go check it out right now!
Hmm. just looked in the manual and found this. It is on the arm rest buttons, not the settings.
Image did not copy.
Reverse parking aid function
(if equipped)
When you move the shift lever to the
R (Reverse) position, the side view
mirror(s) will rotate downwards to aid
with driving in reverse. The position
of the side view mirror switch (1)
determines whether or not the mirrors
will move:
Left/Right : When either the L (Left)
or R (Right) switch is
selected, both side view
mirrors will move.
Neutral : When neither switch is
selected, the side view mirrors
will not move.
The side view mirrors will automatically
revert to their original positions
if any of the following occur:
• The Engine Start/Stop button is
pressed to either the OFF position
or the ACC position.
• The shift lever is moved to any
position except R (Reverse).
• The remote control side view mirror
switch is not selected.
Yeah... found the mirror thing in the manual. The mirror switch on the door has to be in the "neutral" position - i.e. neither mirror selected. Didn't know it was in the "steering wheel" menu as well.
I'll check for "black" in the NAV menu again in the AM - I think it was greyed out yesterday right after I made the update.
