Used 2015 Genesis 3.8 Tech pkg, or 2013 Equus Signature?
rickkapur
San Jose, CA
Used 2015 Genesis 3.8 Tech pkg, or 2013 Equus Signature? What would you recommend, and why?
Both have similar mileage (about 40k miles), similar price and similar carfax/owner history.
Thank you
Unless you like to be chauffeured in the back seat, it’s a no-brainer to go with the newer car and technology. Be sure to buy a good extended warranty.
Thanks
I own a Genesis but have not had any extended experience with the Equus. Thought that equus is supposed to be higher quality, better ride, trim, 5.0? Does the 2015 even with only 3.8 outweigh those?
Thanks
Rick, if you already own a Genesis, maybe you want to change it up a bit?
The Equus is more luxurious, more spacious, and does have the 5.0L V8. But it ultimately depends on your priorities.
Thanks
Thanks
It is all in the perception of value to you. On the market they are about the same price as you note.
Higher quality? Sure it may have a bit better grade of seat material or carpeting but the assembly tolerances and fender material are the same. Do you often have rear seat passengers? They will be impressed with the Equus. Sure, the 5.0 is a nice engine but the 3.8 is reliable too. As for performance, the 0 to 60 times are both rated at 5.9 seconds so the more power is hauling more weight at the same speed.
Drive both and see what fits YOUR needs best. Where you park may make a difference too.
Thanks
Thanks
The Equus is yesterday +. Pick your poison.
