Value making tapping noise
martyk
I've got a 2012, 4.6 V8. I've put approximately 15000 miles on it. The values started to make a tapping sound. I use M1 syn, 0w-30 oil.
I heard the engine "tap" on cold start up, while the car was running in the garage. I was wondering if any of you with the V8's have this tapping noise or have heard anything about it.
Thanks, Marty
Thanks Scott. I think the car was sitting for 2 days before we started it up. The oil may have drained out of the lifters. The next day when we started it up there was no tapping sound. After the engine get hot it is dead quite.
Marty
Marty
Make sure you use Hyundai OEM oil filters. Some have reported problems with after market filters. Hyundai has issued TSB s regarding not using OEM oil filters.
I have Hyundai do my oil changes.
Marty
Thanks, Marty
5w-50 is recommended for the 4.6.
5W-50? No way that is the "recommended" viscosity. There have problems reported with some of the 2012's and some use excessive amounts of oil. I suppose a higher viscosity might help, but I would not go beyond 5W-40. But if it is using oil, or making unusual noises, I would take it to the dealer and file a warranty claim. Most likely the dealer will blow you off, but just contact HMA and open a case with them. HMA has replaced a number of 2012 V8 engines due to design defects (since fixed in more recent versions of the engine).
Sorry man my bad...I meant 5w-20.
