We Brought the Korean version of Full LED HID lights
Uchiha madara
Finally we brought the Korean LED lights that we saw them in the opening the brand in KOREA
those lights belong to G80 and we installed them in our cars
and its same LED lights like mercedes S class
So? How well do they work?
I assume they will last forever.
I would think the BCM and other electronics might be different so that they are not plug and play - especially as the marketing tout that he beam pattern adjusts to different conditions?
So do they actually work?
i have 3 questions are they plug and play if not how did u get them to work and were did u get them because i like to buy them my self thank you
its plug and play normally and they are strong lights exactly like what is in Mercedes S class
the only problem is the side view light the its on when you trun the steering is not working maybe it need the lights computer to be changed with korean version
and its really white blue light unlike the original one we have its close to be yellow
the prices from korea to Saudi Arabia totally is 7900 SAR that means 2100 $
its kind expensive but it deserve it and that is Genuine part
Buyer beware. This is NOT plug-and-play.
actually it is plug and play with our and your cars
the korean version genesis that it comes with 4 xenon lights need some modification on it
but our version in Saudi Arabia and yours only plug and play
I highly doubt it's "plug an play" - the 2015/2016 KDM HID dual projector setup was not. At the very least,the second headlight needed separate power run to it and there were still issues with signal routing for the DRL's (as Aquineas found out).
Can you post pics/videos to show how you wired and that the headlights are working (high beams too)?
Well maybe the KDM lights are different now (they do look different around the headlamps), or they're different on the G80. Here are the KDM lights on my car, which I also paid $2100 for in February, 2015
picture.php
See this thread for the discussion.
Short summary, I used the adapter that came with the lights, and I (and at least two others who bought these) still get a flashing amber light instead of a daytime running lamp when the lights are set to "auto" in the daytime. My choices are to manually switch the lights to accessory mode or to drive with the DRLs off (which is what I do). I spent at least $300 in labor fees (with a Hyundai Master Tech) trying to (unsuccessfully) get this resolved. I'm stuck with it for the next 4 1/2 years
Those look great, I would buy if they're an easy enough install
ooo I like the lights already tho and that gold wrap me gusta
in the dual projector version you need 2 wires in the Full LED you need only 1
the same wire that we have right now
i will post the videos and wiring pics
Thanks Uchiha. It's certainly possible you found a solution or that your lights or BCM (body control module) are different, and if so, that would be awesome! Please note that I too had to have a separate wire run for the high-beams.
To fully verify the solution, can you please verify the behavior of the lights when they're set to "auto" in the daytime? Put the lights on auto (showing the daytime running lights), put the car into gear, move forward a little bit, then put the car back into park. On mine, the amber flickering didn't display immediately.
Schindawg (the guy in the other thread) thought he didn't have amber flickering either (but he did).
Did you read his post? It doesn't work correctly.
the dual projector one need modification to work
but the full LED ones doesn't need any
just plug and play except the side view lightning the it go on when you turn the steering wheel is not working
