What about these
Jalexe
Huber Heights, OH
since i doing reseach on the Genesis Sedan..im looking at wheel set ups....so i came across these..
so the qustions is what offset should get these in 20x9/20x10.5 to sit flush (or as close to as possible without poking out)
Those look really nice. What is your budget? I have been looking myself, as I hope to get a pre-owned Genesis next month. Here are the rims I'm considering. Google them and look at the cars that have them. I think any of these would be killer myself.
RS-55 by Concept One Wheels
Hennessey by Vertini Wheels
RW 1 by Roderick Luxury Wheels
093 by MSR
There are so many rims that would really set off the Genesis nicely! Good luck!
You cold do this... assuming you don't care for the "stanced" or "stretched" look....
265/35/20 up front running the 20x9 +32
295/30/20 in the rear running the 20x10.5 with a +22
Both of these would clear provided you rolled the rear fenders and took time to double check everything. There's always room to run more agressive offsets / setups with the understanding that the role this plays on your wheel bearings, tire life, suspension etc.
Rims and tires has a great calculator that I highly recommend if you plan on doing any type of custom setup -- staggered or not.
http://www.rimsntires.com/specs.jsp
im all about the stance look........i was think about running 225/35/20 (f) and 245/35/20 (r)
How aggressive? Are you willing to roll the fenders?
Those tire sizes you listed would really throw off your gearing, stearing ratio, and a number of other things.
If you want the stretched look may I suggest 225/35 up front and 265/30 out back. This will keep the rotations about the same front and rear. You can play with your offset from there. Use the +32 as your starting point with OEM flush fitment. If your getting coils I recommend installing the coils first, check your clearances, then pick the rims. Clearance, and setup will change once your dropped.
The 225/40 would not be considered a stretched up front. Drop down to a 20x8.5 with a +30 on OEM and you'll be able to achieve that. 265/35 in the rear would be a slight stretch if you go with a 20x10.5 -5 to achieve the look / stretch accounting for the fact that you'll be rolling the fenders.
Definitely heed jnc's advice on tire sizes out back... for instance
I run 235/35/20 and 275/30/20 on 20x9 +38 and 20x10.5 +42 rims myself. ('10 Accord Cpe on coils)
I consider it enough of a 'stretch' on the tires and I we mounted up a General Exclaim UHP in 265 size and it was just too much stretch for my own liking, however, I'm not aggressive w/ my camber no trying to 'poke' -1.5f/-2.5r.
Plenty of people run 265 successfully on a 10.5" wide rim, I just prefer a slight more meat when viewing a 275 or even 285 from out back. 265's are more widely available though, so you have to take that into consideration.
i will keep that i mind...matter of fact i was sort of going off what your set up was....love those vossens
