What are you other rides?
slaugrc
McDonough, GA
2007 Z06, HRE wheels, Wilwood brakes all around, Breathless CF intake, MGW shifter, WAY more to come (only had it for a month)
2007 ZX10-R, 10" over swingarm, slammed, 5 up in the rear, 2 down in the front, PCIII, Brock's Sidewinder, K&N, Dyno'd 175RWHP. Runs 5.9 1/8 mile with no air shifter.
Sold for the Vette...2003 Dodge Ram, Cummins Diesel, too much to list, 700RWHP, 12.3 1/4 mile @ 7800lbs
My rides are listed with my signature below. Plus a 17' Hobie Cat for the beach.
'06 Harley Road Glide
95" motor, 103 HP/104 TQ. Custom body work and paint. All done by me.
I like that color, its hard to tell whether it's changing color or goes into black.
Hyundai Sonata, this is my third Sonata, great utility car. V6 Limited
Loaded 2012 Volvo XC60, T6 300-hp Turbo, Platinum Edition, black/saddle and Four-C adjustable chassis system for on-the-fly adjustments to damping, roll stabilization, steering and transmission shift points. It has a few features I wish my R-Spec had!:confused:
Beleive it or not, the whole paint scheme began as a screw up.
I started with a black base coat using House of Kolors black base.
The original concept was stripes done in the Kopper Penney pearl you see. Then a Red Pearl on the upper half and a Gray pearl on the lower half. This was all dry pearl flakes you mix into the clear before spraying.
Well the red looked too pink and the gray too silver. But the Kopper came out nice and had had a nice fade from the overspray. So we sanded it all down and redid it. Heavier layers on top and fewer on the bottom with some just a dusting of the Kopper. That's how we got teh fade and why some of the black looks a little brown, like on the front fender. It looks even better in the sun.
After all the color was sprayed, we put on a couple of thick coast of Dupont high gloss clear. I light color sand to smooth it out, a little cut and buff. then some wax. It's smoother than a babys butt and deep in the color. Looks wet after a good coat of wax.
1986 IROC Z28, all original, 305 TPI with the 700R4 and 4 wheel disc brakes. Black with gray interior.
2006 (or is it 2005) Silverado 4WD with 4.8 V8 and 5 speed manual transmission (this is the gas hog, 4.10 rear and aerodynamics of a brick.)
The 81 Z28 (350/4 Speed) is licensed/insured but I don't drive it, except in/out of the garage and up/down the road in front of my house now and then to get it hot and circulating the antifreeze a little.
