What diagnostic equipment is used on the Genesis?
rlbatch
What shop diagnostic equipment is used to check codes and diagnosis faults on the Genesis?
Where is the OBDII port located on the 4.6?
It's way up under the dash towards the left side.
Once you get a feel for where it is, you can hook up a code reader without seeing it. You'll probably need a flashlight and have to "dive" down in the footwell to see the port the first time or two you try to hook up.
Thanks-will check it out.
