WOT BOX help
parkercap
No Genesis Yet!
Okay I have a 2001 hyundai tibuon and i've been installing a wotbox for the past 2 weeks and have run into a problem the clutch position sensor on my car is running a 1volt system and is only picking up when the clutch is down. does anyone know what to do to get it on a 5 volt system i've tried following the down sensor and it runs into the ecu the up sensor runs into a different pin in the ecu. Also there are no ecu diagrams for my car, so can I put in a clutch position sensor on its own system to get it to 5 volts or what should I do.
Well, to start off, this is a Genesis forum so I'm not sure how much help you'll get for a Tiburon, unless you really have a Tibuon in which case, I've never heard of that one at all. I've also never heard of a clutch position sensor on a fully manual none DSG/Dual clutch transmission.
What exactly are you trying to do? What is this wotbox you're talking about?
